My V8 S-10 (lots and lots of pics)
Old 04-26-2008, 08:28 PM
  #21
Tod74
Originally Posted by olds48
What kind of disconnect do you have and how old is it?Some of them are not rated for the amperage it takes to start a car.746 watts equals one hp.Watts divided by voltage equals amps.So..if you have a mini starter rated at 2 hp that is 1492 watts.1492 watts divided by 12 volts is 124 amps!!If your voltage drops to 8 volts(which is not that uncommon if you watch your gauge) it would be 184 amps.ALOT of the cut-off swithches people use are only rated at 20 amps continous and 200 amps intermittent.Not much of a switch considering all the electronics some guys run.Water pump,elec fan,ign box(which is not much),1 or 2 fuel pumps,and then when you pull your lights on at night...20 amp switch barely covers your head/tail lights.doesn't take long to max out one of those babies.Check your switch.If it being overworked it could be losing alot of voltage where it has been overheated from over-amperage.Might be cheaper than buying alot of cable.Moroso makes a severe duty switch rated at 2,000 amps intermittent and 300 amps constant.Goes for about $60.Just a thought :?
damn dude....you're pretty smart. seriously. I never gave that stuff much thought. I hate wiring.
Tod74 is offline
Old 04-27-2008, 03:27 PM
  #22
olds48
It's what I do for a livin' They made me learn it
olds48 is offline
Old 04-27-2008, 04:23 PM
  #23
Tod74
yeah you better know what your do'n when working on someone's house !! :lol:
Tod74 is offline
Old 04-28-2008, 08:39 PM
  #24
olds48
olds48 is offline
