SLOW 1-2 SHIFT ON TH400
Pulled the valvebody out and checked the valves today.Everything looked okay,went ahead and cleaned everything up,but none of the valves seemed to be sticking at all.The tranny doesn't slip at all,so I hate to tear it down to air check the clutches.Maybe I'll run a pressure test and see what my line pressure is before I yank it out.
Okay.clutches not leaking and pressure test showed about 160 pound.Talked to I guy I know who runs 4.50 in the 1/8.He said that he went to a glide to get away from that problem.Said he was told that the clutches/drums are so heavy in a TH400 that it can't be prevented to have a little lag.Don't sound right to me.
#18
Any other suggestions?One guy I talked to at a local transmission shop said to drill 1/8 holes ("about 20 holes in all")in the clutch drum to help fluid escape quicker???Sound like anything ya'll ever heard
#19
There is no reason for you to have any delay with a 400 if all is right. You either have a valve body issue or a pressure leak in the trans itself. Second gear is in the center support which is fed from the center support bolt area. Is there a bolt in it? That would give you a fair leak. Lip seals on the intermediate piston could leak, last would be the valve body itself.
