offset pinion
Old 12-22-2007, 06:17 AM
olds48
That's kinda what I thought ,too ED.It was the having an up-and-down angle with a side-to-side angle (compound angle?)at the same time that made me wonder if it would bind.Thanks Eric
olds48 is offline
Old 12-22-2007, 06:11 PM
Bubstr
JUNIOR BUILDER
I wouldn't worry about the angle. Start worrying when you get them too straight. The straight u joint can vibrate and not only waste U joints but Tail shaft bushings and pinion bushings.
Bubstr is offline
Old 12-22-2007, 07:16 PM
olds48
Did not know that,Bubster.Thanks for the info.
olds48 is offline
Old 12-23-2007, 12:17 PM
olds48
Looked at the Strange 12 bolt center section on their website.It says that the 12 bolt pinion is more center of the ring gear compared to a 9",couldn't find where it said if it would cure my offset or not.Anybody got any experience with the 12 bolt piece or got a buddy that does?
olds48 is offline
Old 12-23-2007, 02:46 PM
SST4530
DYNO TECH
The pinion is always offset to the right side of the ring gear. Far as I know any rear end has one side shorter than the other unless it's been cut with equal axle lengths. Then you have the situation your dealing with now. Doesn't sound to me like enough angle to worry with, the only other issue that would cause vibration besides having the shaft to straight would be if the shaft yokes were installed out of phase. This will make one shake like a belly dancer! :lol:
SST4530 is offline
Old 12-24-2007, 05:10 AM
olds48
THE 10 BOLT I'M REPLACING HAD EQUAL LENGTH AXLES AND A CENTER-SET PINOIN.ANOTHER POINT PROVING CHEVY'S ARE SUPERIOR
olds48 is offline
Old 12-24-2007, 06:19 AM
lookingaround
if im not mistaken i read somewhere where all rears are offset just a little. i know on a camaro and nova the whloe rearend is offset to the passenger side.if im wrong im sure someone will correct me.
lookingaround is offline
Old 12-24-2007, 07:19 AM
  #18
lively
lively's Avatar
i would say 90% of racers and street cars have FORD OR CHRYSLER REARS!!!!!!!!!!!!!---LIVELY :lol: :lol: :lol: :lol:
lively is offline
Old 12-24-2007, 07:21 AM
  #19
lively
lively's Avatar
HEY--OLDS48-----YOU GOT MORE PICS AND INFO ON THE CAR IN THE AVATAR???---NEET LOOKING AND DIFFERENT!!!! 8) :lol: 8) :lol: ---LIVELY
lively is offline
Old 12-24-2007, 08:18 AM
  #20
jmarksdragster
jmarksdragster's Avatar
A 12 bolt will move it more center than a 9" and it takes less power to turn than a 9". My suggestion is to call Strange, if you have to buy a center section anyway it might be a good solution. They should be able to tell you the measurements to see if it will help enough.
jmarksdragster is offline
