1/8 time 60ft time
Old 11-19-2007, 12:35 PM
bjuice
Administrator
bjuice's Avatar
u answered part of your problem in your question...
other than that
more gear
possible after market suspension cal tracs, slide -a-links etc...
i can tell you now that your 383 is not going to pull your 3400 Lb car out of the hole without a bunch of gear.......
so your 60 ft is about right for what you have motor/chassis and 3400lbs.
plus your tire size ( height) was never mentioned...this is a key role.
Brian
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
bjuice is offline
Old 11-19-2007, 07:15 PM
jmarksdragster
jmarksdragster's Avatar
5500 converter and at least 4.56. You won't hurt a good converter on the street, just your mileage.
jmarksdragster is offline
Old 11-22-2007, 05:19 PM
ash
With a `glide, you will need a gear set in the 4.88:1 to 5.13:1 range with that kind of weight. Unless you run more HP, the other option is to get the torque multiplication from the gears. Just my $.02.
ash is offline
Old 11-29-2007, 10:50 AM
mopar1968
mopar1968's Avatar
Default 60 ft times
kenny383, check your convertor, my car did the same thing convertor was locking up.
mopar1968 is offline
