car bogs leaving line
Old 11-05-2007, 03:33 AM
alleyk
APPRENTICE
tod i do both, only happens when foot braking, i leave on a pro brake at 5400 and thiers no problem,just curious to know why on foot braking i have this problem.
alleyk is offline
Old 11-05-2007, 03:37 AM
alleyk
APPRENTICE
cepx111 my last reply is for u as well
alleyk is offline
Old 11-05-2007, 05:04 AM
davis419b
Im not sure what fuel you are running but can you deck the throttle while just setting in the pits without the hesitation?
davis419b is offline
Old 11-05-2007, 03:02 PM
alleyk
APPRENTICE
running c14,when i deck throttle in the pits it doe's hesitate
alleyk is offline
Old 11-05-2007, 04:59 PM
davis419b
I run alcohol and when mine wont deck clean i have to adjust the 4 corner ilde screws to richen it up so it will deck clean, shoudnt be any different with gas!
Old 11-05-2007, 06:34 PM
hammertime
I agree its likely in the idle screws. A guy that pitted next to me @ norwalk this year had same issues and ended up being the idle screws.
hammertime is offline
Old 11-06-2007, 02:27 PM
alleyk
APPRENTICE
hey thanks guys i'm going to try adjusting the idle screws ,and see what happens.
alleyk is offline
Old 11-06-2007, 02:30 PM
  #18
SST4530
DYNO TECH
I think I would lean more toward accelerator pump, pump cam, and squirter size. Be sure when foot braking your not using all the pump shot when stalling at the line. also if your not running 50 cc accelerator pump on the front get one.
Don't need it with trans brake, but foot brake it's a must.
SST4530 is offline
Old 11-26-2007, 11:18 AM
  #19
youtellme
spring on the rear pump is too loose.
youtellme is offline
Old 11-26-2007, 07:38 PM
  #20
fishman1
Originally Posted by alleyk
538 gears,12to1 comp,6000 stall.
with only 12/1cr why r u running c14 just curious....r u turning high rpms
as i have 13.5 cr and i use c12 will no issues and timing at 40 degrees total
fishman1 is offline
