experience with 16 volt batteries
Old 05-20-2009, 05:58 PM
  #31
hammertime
sounds like this guy isnt having good luck with the vbattery either
http://www.racingjunk.com/category/1...-battery-.html
hammertime is offline
Old 05-20-2009, 06:17 PM
  #32
TheRabbit
TheRabbit's Avatar
I'd rather buy it in person too. Somtimes mail orders have some supprise charges!
TheRabbit is offline
Old 06-01-2009, 04:58 AM
  #33
TheRabbit
TheRabbit's Avatar
Finally had a race since I put the 16 volt in. No way would I run a 12 volt again. The 16 volt battery and charger are expensive, but worth every penny.
Old 06-02-2009, 10:30 AM
  #34
I972Nova
I am really leaning towards a 16 volt battery. Looking at the PowerMaster S1000. I have ruined 3 flywheels and 2 starters with my 15:1 small block and I think this may be the answer.
I972Nova is offline
Old 06-02-2009, 02:41 PM
  #35
dparker
12 volt with alternator much better. Usually if you have a good starter and have it aligned right and are still breaking flywheels its because your moter is kicking back.
dparker is offline
Old 06-02-2009, 04:39 PM
  #36
TheRabbit
TheRabbit's Avatar
Don't have room for an alt. Vacuum pump and a dry sump in a Toyota doesn't leave much room for anything else. And a 12volt with 4 batteries will never give you the starting power of 1 16 volt battery
Old 06-05-2009, 05:29 AM
  #37
chevyfireball
I run two 16v batteries and put on the charger between rounds. Can't risk a voltage drop off.
There has been a whole lot of discussion concerning V batteries on
http://www.promodzone.com/showthread.php?t=16456 and also
http://www.promodzone.com/showthread.php?t=15815 and also
http://www.promodzone.com/showthread.php?t=11890
These threads orta put you off ever touching a V battery. Worked for me!
chevyfireball is offline
