engine stuff
05-23-2007, 02:54 PM
You could check the drive shaft Carl. I always put the shaft all the way in the trans bushing and like to have no more tan 3/4 inch back to the rear end yoke. Too much slack will give you a vibration.
Is the rear tranny mount OK? Also do you have solid mounts or rubber? I like to use solid mounts with rubber trans mount. It does give you more vibrations but they won't break. Just my thoughts.
05-23-2007, 03:49 PM
i call shot gun. o yaa your to dam far away for me to call that. nice job hope it craps the scare in you or scares the crap out of you.
05-23-2007, 04:16 PM
glad to hear ya got it home carl
05-24-2007, 06:20 PM
Less than 24 hours to track time.
I can tell it will be spinning at least through the 60'.
05-25-2007, 05:12 AM
Administrator
Don't worry its a common problem we all have !!...Good luck and let us know how it turned out...
later Brian
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
05-25-2007, 11:21 AM
SENIOR BUILDER
GOOD LUCK AND CONGRAT'S, CARL
AL
05-25-2007, 09:56 PM
Results are in....I need Slicks...BAD!!!!!!!!!!
I will post more tomorrow, right now I am tired and bed is calling....
05-26-2007, 01:05 AM
Like I said Carl, I've got those M&H's.....
I'm glad that you have that much power!!! Can't wait to hear about your track time, as I won't get to the track until June 9th. :cry:
05-26-2007, 04:28 AM
ok carl wake up and let us know.
05-26-2007, 05:51 AM
Carl its time for some numbers. Wesley
