everybody post a pic of there ride
#631
JOURNEYMAN
Rabbit
am asking this question in an "educate me" tone (am not questioning your set up)
You have a 4 stage dry sump with all stages pulling from the pan, why not from the lifter valley or rear of the heads ?
also - what kind of carburetion will you have on this ?
#632
The majority of the oil is gonna be in the pan and the lines have to be completly submerged in oil to work. Oil drainage from the heads and lifter valley would not be enough to supply the pump.
AED carb running Q16 fuel.
#633
JOURNEYMAN
I run mine from the pan only as well, and have thought I was lacking by not having it pulling from other passages.
Other set-ups I've seen (like on nascar dry systems [no - am not a nascar fan] - or formula) I've seen where they have 2 of the 4 stages pulling from ea. side of the rear of the head, one pulling from the back of the lifter valley (thru the block - or down thru intake) and one from the pan... but have also seen like yours - pulling from the pan only.
I guess as long as your getting the oil where it needs to be it's all good.
#635
The guy that built mine was a Nascar egine builder for a few years for Gibbs. I'll have to ask him to help me on this. The only way I've ever seen it done on a drag motor is out of the pan.
#636
JOURNEYMAN
#637
OK plane and simple ( which is how I asked him to explain it to me)
You want to create the most amout of vacuum possible with the oil pump. With only 4 stages like mine you put all of them in the pan under the rings.
6 stages you would put the other 2 in the head and lifter valley which really helps keep the windage down.
Hey thanks for the ? I learned something new.
#638
JOURNEYMAN
"knowledge is power... literally"
