1977 Camaro 49,000 original miles
Old 08-22-2016, 06:45 AM
Harbone
Moderator
Harbone's Avatar
Rear floor pans are spotless
Rear seats cleaned up, everything vacuumed out and wiped down before reinstalled
Chris
Harbone is offline
Old 08-22-2016, 06:46 AM
Harbone
Moderator
Harbone's Avatar
Rest of car cleaned out and ready for front seat install
Chris
Harbone is offline
Harbone
Moderator
Harbone's Avatar
finished up, cracked a beer and relaxed the rest of the night after taking some sunset pictures
Chris
Harbone is offline
Old 08-22-2016, 06:47 AM
Harbone
Moderator
Harbone's Avatar
Got up Saturday and installed the new 3 piece front spoiler, too a little working around and a few new holes drilled but it looks good
Chris
Harbone is offline
Old 08-22-2016, 06:48 AM
Harbone
Moderator
Harbone's Avatar
Things were going well until I opened the box that had the used U41 cluster in it to get ready for install, glad I didnt start swapping wires just yet...
Can anybody see what the issue is here?
The cluster that supposedly came out of a 77 is obviously out of a later year since the turn signals are located in the wrong position
So I tore the original cluster out anyways since its just flopping around and needed secured. Good news is the inside of the dash area is really clean
Chris
Harbone is offline
Harbone
Moderator
Harbone's Avatar
The bad news is, whatever kind of repop dash this is has no structural support where the instrument cluster mounts! its literally just loose, sloppy rubber with no reinforcement...WTF?!?!?!?
Whomever had installed the dash pad had just installed to metal brackets to the existing cluster where the tabs were broke off on the top and screwed it into the rubber, well since the bottom had no attachments it just ripped right out!
So I took some spare scrap metal I had laying around, made some lower brackets for the cluster and some reinforcement for the cluster mounting points. I was cussing the whole time but managed to get it firmly reattached or at least as good as it gets for what I was working with
I walked away after that and spent the afternoon playing with the dogs in the yard
One last thing I did play around with is the Ziebart rustproofing thats sprayed all over the engine compartment. I put some paint thinner on a rag and started scrubbing, its going to take some patience and elbow grease but I do believe it will all come off. Here is the spot I did on the passenger fender.
Probably save that project for a rainy day or the dead of winter...
Chris
Harbone is offline
Old 08-22-2016, 04:17 PM
Swiley383
Swiley383's Avatar
The seats look good. Nice solid floors are always nice. Are you going to do any motor upgrades?
Swiley383 is offline
Old 08-22-2016, 05:05 PM
  #18
Harbone
Moderator
Harbone's Avatar
Swiley I might do headers, intake, carb and cam
Going to tighten up the suspension first, get some tunes in her and save the motor work and engine compartment detail for the winter time
Chris
Harbone is offline
Old 08-22-2016, 10:01 PM
  #19
mytmouz
mytmouz's Avatar
Nice car...
mytmouz is offline
Old 08-25-2016, 09:34 AM
  #20
Harbone
Moderator
Harbone's Avatar
finally got her to work so I could align the front end ( was pulling to the right and the steering wheel was off to the left) and get a good look at the underside since my floor jack took a crap on me last weekend.
Front end aligned out OK which was great considering everything looks original. Nothing is super loose and now she goes down the road pretty straight. The front subframe is pretty "lubed up" from all the oil seepage and a decent power steering leak.
Chris
Harbone is offline
