383?
#11
Originally Posted by ajk
Originally Posted by cncmotorsports
You hear these stories cause they don't cam them right, and people use crappy heads.
Don't be surprised with pro comp heads this motor is done making power at 6200-6300 rpm..
1 bad part in the balance of these components will make the engine suffer.
We build 383s for drag race and circle track designed to run 8000-8200 RPM.
Good heads, AFR, Dart, RHS, Brodix and Edelbrock are not to bad.
#12
cnc dont see the balaning being an issue friend of mine built one for circle track lasted 3-4 seasons with nothing more then freahening bearings for his own peace of mind then when he rebuilt no major issues in side just went through it again for peace of mind so i dont know where your coming from
#13
I was not referring to the engine balancing it's Self.
#14
[quote="cncmotorsports"]
Are you implying that running a 383 over 7000 means it is not cammed right? if yes why? Just a question..What do you consider crappy heads?AFR,pro Comp,Dart?
It all depends, camshaft, cylinder head, intake manifold, carburetor and compression play a huge factor in where the engine will make peak power, and how long it will carry that peak power.
Good heads, AFR, Dart, RHS, Brodix and Edelbrock are not to bad.[/quote
read your own post
read your own post
#17
1 bad part in the COMBINATION of these components will make the engine suffer.
There, fixed it to save arguments.
#18
