Need help on BBC alcohol tune.ROOKIES
Old 06-11-2008, 08:52 AM
  #21
I've got to ask why change it 2-3 times a day ??
Once you get it set the only change you should make all year is a pill change from hot to cold or cold to hot weather ??
I run return straight to top of fuel cell, crank trigger MSD.
Barrel valve leak changes with the weather, just like the main pill does.
I take it you don't own a weather station.
I do .. mine stuff doesnt get changed at all, all year. Toilet or Terminator must be I am just lucky. I know NO one who changes the BV once they get it set where the car likes it. I dont even change the pill in my setup its good either way. Spring Weather to Hot Summer weather no change 7.55 in spring 7.55 in hot guess I got lucky.
Just because I thought of it... Aren't you running a normally aspirated motor?
Old 06-18-2008, 12:55 PM
  #22
olds48
Hey Hammertime.Those look like Moroso Super 40 wires.You like those pretty good?BTW ,thanks everyone for their help,once we got the leakdown right,everything else kinda fell in line behind it.THANKS EARL!!
olds48 is offline
Old 06-18-2008, 01:17 PM
  #23
Them are the blue spirals the step below the ultra 40's. I had the ultra 40's last year both are good wires.
Old 06-19-2008, 11:08 AM
  #24
suicidebomb
You're most welcome Olds48
suicidebomb is offline
Old 06-19-2008, 01:11 PM
  #25
olds48
Thanks Hammer.Thanks again Earl
olds48 is offline
Old 06-19-2008, 01:13 PM
  #26
not a problem ..
Old 06-19-2008, 03:01 PM
  #27
suicidebomb
Glad I could help,
