SBC OIL PUMPS
Old 09-14-2009, 07:33 AM
oldandtired
oldandtired's Avatar
Default Re: oil pump
Originally Posted by JimmySmith
We use a Meling SELECT. Later J.Smith 4621 racing
x2 Available in +10% or +25% volumn, larger inlet hole, threaded pressure relief spring plug and the gear shafts go into the cover.
Then (like DD said) totally dissambled and blueprinted.
Dave
oldandtired is offline
Old 09-14-2009, 06:05 PM
jaxsmith
Pops always said "We use a Meling SELECT. Later J.Smith 4621 racing " I dont change anything he says T Smith 4623 racing
jaxsmith is offline
Old 09-14-2009, 06:41 PM
Tod74
how do you blueprint an oil pump? What are the measurements and tolerances and how do you adjust them?
Tod74 is offline
Old 09-15-2009, 12:03 AM
cepx111
Good question Tod, I just deburr everything real good, make sure everything operates smoothly, loc-tight the cover bolts weld pick tube and be done with it.
I've always run Melling HV pumps, never had any problems.
I have heard about the powered metal gear problem(s) but I have yet to see one that has failed>
I'd Like to know more about it and when the switch to powered metal gears was made.
Anybody?
Now if money is not a object then go with a Titan, they are bulletproof.
www.titanspeed.com
Cp
cepx111 is offline
Old 09-15-2009, 05:46 PM
promod45
JUNIOR BUILDER
Default oil pump
CVR a good pump for the money, they have really good stuff check them out
promod45 is offline
Old 09-15-2009, 06:29 PM
et7333
Thats hard to do when they don't answer their phone or emails.
et7333 is offline
Old 09-17-2009, 05:48 PM
promod45
JUNIOR BUILDER
Default oil pumps
Thats hard to do when they don't answer their phone or emails......... i agree but it might be your time zone difference i had that problem to but once i figured it out i got ahold of them right away and competion productssells there stuff to if you know what you want
promod45 is offline
Old 09-17-2009, 06:17 PM
  #18
markdunlap
Default SBC oil pumps
I tried for months to buy CVR BBC oil pumps from Competition Products and direct from CVR. All I ever got was "They are out of stock" or "Production has been delayed" from both of them. CVR would answer my emails but never would tell me when I could get my hands on one. Competition Productd would just keep trying to upgrade me to a CVR aluminum pump which I did not want.
I wonder if they have actually ever produced any at any time?
markdunlap is offline
Old 09-19-2009, 09:50 PM
  #19
us7race
Melling Select 10552 10% more Volume high presssure, Designed to be Happy at 70psi. Been running it for 2 seasons now with Very good Results.
It is made for a Bolt on or press in pickup tube but I ended up having to use a press-in style and welded it fully.
us7race is offline
Old 09-22-2009, 07:02 AM
  #20
THERATTLER
THERATTLER's Avatar
I use Melling part # MEL 10552 around $50 bucks never a problem, has bolt on pick-up and steel billet gears and cnc machined gear cover,,hard to beat for the money,,,,Paul
THERATTLER is offline
