ENGINE OIL PRESSURE
Old 04-28-2009, 09:08 AM
beerbelly
Default ENGINE OIL PRESSURE
ANYBODY GIVE ME ANY HINTS ON WHY I'M DROPPING ABOUT 30 LBS OF OIL PRESSURE AT 5200 RPMS IN A DRAG BOAT WITH BRAND NEW 454. COULD IT BE RUNNING OUT OF OIL AT THE PUMP OR IS IT SOMETHING MAJOR ANYBODY?
beerbelly is offline
Old 04-28-2009, 09:26 AM
BEAST477
BEAST477's Avatar
I hope you're not using a Fram oil filter.
BEAST477 is offline
Old 04-28-2009, 09:49 AM
beerbelly
Default no fram
nope using a wix racing filter
Old 04-28-2009, 10:05 AM
TS1955
Just a thought...Does this engine have a "stock" oil pan & a high volume pump? I've seen this happen before. A high volume pump can suck a 4 qt pan dry. Just something to look in to. JMO
TS1955
TS1955 is offline
Old 04-28-2009, 06:43 PM
bowhay
i have a high volume in a stock pan and it works fine
but its a 5 quart, it also holds closer to 6 though at the ful mark
what size is ur pan
bowhay is offline
Old 04-28-2009, 08:38 PM
dparker
Default Re: ENGINE OIL PRESSURE
Have you plugged the bypass above the oil filter. I've seen them open to bypass and pressure drop. The first thing I would do would be to cut open your oil filter and look for any metal. Nip that in the but first.
dparker is offline
Old 04-29-2009, 07:17 AM
topsportsman1
Sounds like the spur gear pump (Oil pump) is cavatating
topsportsman1 is offline
