Oil Pan gasket blow out SBF...need advice
Old 02-18-2008, 04:04 PM
Stappy
Default Oil Pan gasket blow out SBF...need advice
Hey guys I got a 408 Stroker, that the rear oil pan seal keeps blowing out. Any suggestions? Normally aspirated 950 Flowtech carb, headers, 600 lift cam with a Super Victor intake.
Thanks!
Stappy is offline
Old 02-18-2008, 04:37 PM
lookingaround
is the pcv valve clogged? if the block builds up to much pressure it can blow seals.
lookingaround is offline
Old 02-18-2008, 05:02 PM
OneBadGMC
Kinda doubt that a 406 stroker with a 950 carb will have a PCV on it.
If you're using the chrome style breathers with the foam in them, try and blow through them with your mouth. Chances are they've filled with oil or condensation and are clogged.
Of course, you would think that it would blow out the dipstick tube first depending on whether the end of the tube is submerged or not.
OneBadGMC is offline
Old 02-18-2008, 05:57 PM
Stappy
Thanks...I'll check the breathers. No PCV valve. Nothing much is left stock on this thing.
Stappy is offline
Old 02-18-2008, 10:10 PM
Definetly sounds like your pressurizing your crankcase with blow by. A crankcase evac sysytem will help a ton. A quick fix is two vented breathers on the vavle covers.
><Cp
Old 02-19-2008, 08:20 AM
Stappy
You refering to an evac pump or just the hoses down from the breathers to the headers?
Stappy is offline
Old 02-19-2008, 01:39 PM
lively
lively's Avatar
IF YOU HAVEN'T GOT SOME KIND OF VENT THEN YOU ARE BUILDING UP TOO MUCH PRESSURE!!!!!!!!!!-----LIVELY
lively is offline
Old 02-20-2008, 01:01 PM
Stappy
I have two vents coming off the valve covers, with hoses going down into the inner fenderwells. Is this enough, or do I need to hook them into the headers? If I do, it looks like there is a bung already on the headers. Can I just drill and tap that? They are Hooker Super Comps. Suggestions are welcome.
Oh yeah....any suggestions on a quality oil pan gasket?
Stappy is offline
