High speed air bleeds
#22
Originally Posted by bryanm
Well, I went through my Demon and cleaned it all out and it stil does the exact same thing. I called Demon and they were absolutely no help at all, so I guess I will be getting a new carb.
Sorry that you have to re buy something that you already paid for once.
Bruce
#23
If the front bowl keeps filling you have to correct that. It will spill over when you launch and flood it. Either the N&S is bad, a casting imperfection in the bowl, or the float is bad or hanging up. You don't have g-forces on the dyno adding to the problem, possibly just enough to make the difference.
#24
It has a bog in my garage even when it isnt on a pass. If I ease into the throttle it loads up at around 3500 RPM, and it is even worse on a launch. Basically I thnk the carb is junk and with how rude and unprofessional the Demon tech line was I dont really care to do business with them or promote there product anymore. From what I have heard from other people this will not be the last thing to go wrong with the carb even if I fixed it now.
#25
carb
It a shame ... but dont feel bad.. i went thru it. By moving onto another carb you will be rid of that demon headache .. trust me ..i beat on the demon for sometime... But when you get a good carb you will know it and just by covering the basics it will make the demon look like the junk it is.
I like Pro systems for gas and APD for Alky carbs...
just my 2 cents
just my 2 cents
