MSD DIGITAL 7 7530 T
Old 07-12-2010, 04:50 AM
dynaguy03
Default MSD DIGITAL 7 7530 T
Hello All
I have a dragster with the digital 7.. i hooked up my computer and do not see where i can program it to activate my electric shifter.. Also .. is see most of the outputs can only handle 3amps.
So where do i program the MSD to shift 1 time at a certain RPM.??
Thanks In Advance
dynaguy03 is offline
Old 07-12-2010, 05:23 AM
TheRabbit
TheRabbit's Avatar
I have the same box, but I use the MSD monitor mounted in my truck. Here is the link to MSD so you can go to it and download the instruction sheet.
TheRabbit is offline
Old 09-08-2010, 02:13 AM
chevyfireball
If you look on the list there is one that says timer switch, rpm switch. Choose which one you want it'll turn off the other one - sounds like the rpm switch, and set that for the revs you want.
chevyfireball is offline
Old 09-12-2010, 02:15 PM
I972Nova
I set mine to work off the yellow wire which is the shift light in the settings. You can feed the yellow wire to a relay then out to the shifter. The MSD box sends out a ground and the relay comverts it to positive.
Hope this helps...
I972Nova is offline
