CARB IDLE
#21
NO EGT,THE CARB CAME THAT WAY FROM PRO SYSTEMS AFTER I TOLD THEM MY INGINE SPEC'S AND CAR SETUP.THEY SENT SPARE BLANK BLEEDS.IF I NEED TO DRILL THEM WHAT SIZE SHOULD THEY BE DRILLED OR CAN I BUY BLEEDS LIKE YOU CAN BUY JETS?I ADJUSTED THE FRONT SQUIRTER AS I THOUGHT IT WAS TO LOOSE,I TIGHTEN IT UNTIL I HAD NO OR VERY LITTLE PLAY .
#22
