Full Spool on a a street Car
Old 02-14-2008, 08:20 AM
Siggerner
Default Full Spool on a a street Car
I have a ford 9 in im building for a 71 elcamino. It will see a lot of street time with some track. would a full drag spool be ok or should i go with a posi?
Siggerner is offline
Old 02-14-2008, 08:36 AM
curtisreed
curtisreed's Avatar
Posi or Detroit locker if it is going to see mostly street would be my choice.
curtisreed is offline
Old 02-14-2008, 12:58 PM
signsbyesa
the spool can be tricky on the street, it does not give or
even out on turns, makes you cruz slow 8)
signsbyesa is offline
Old 02-18-2008, 04:57 AM
i agree witgh signsbysea..i would not suggest full spool on the street..a simple corner can cause a bad push causing saftey issues...go another route you will be more satisfied IMO.
bRIAN
Old 02-18-2008, 05:27 PM
oobob
A spool on wet pavement will get you hurt or worse. :roll:
Mark
oobob is offline
Old 02-20-2008, 08:29 AM
Siggerner
yea i found a posi for it. ill save the spool for the track. thanks
Old 03-28-2008, 06:42 PM
russ67chevelle
not posting to be macho,but realistically speaking,i have no power brakes or steering,my tube chassis chevelle is 2800 w/o me,16x33 m/t e/t streets skinnies up front with spool.ive driven it on street time to time and must say its not as horrible as everyone says!!!your power level dictates your choice.if you have 600 or more ft/torque id probably say spool it if you can get your tire to hook up.especially if its a heavy car.if its around the 600 or less would be fine on a locker.posi trac rears are the weakest of the 3 kinds of rear diff. in my post.
russ67chevelle is offline
