Bead Lock Wheels
Old 12-24-2009, 07:22 AM
jreiley
Default Bead Lock Wheels
I see lots of cars now running with bead locks and I wonder if they really need them. Fuel cars, no doubt, but your everyday bracket car, well I have my doubts. My question is do I need to put bead locks on my car, a 3000lb car with somewhere around 1000hp?
jreiley is offline
Old 01-14-2010, 01:54 AM
chevyfireball
I run 6.8 sec quarters at 198mph and use rim screws. Bead locks look cool, cost a hellova lot and are really only needed over 200 mph.
chevyfireball is offline
Old 01-14-2010, 05:35 AM
I can tell you why most put them on bracket cars ... they are more consistent, its been proven several times.
Old 01-17-2010, 05:00 AM
jreiley
So would you use double or single bead locks?
jreiley is offline
Old 01-17-2010, 05:27 AM
kod99
I was wondering how bead locks are more consistent? I use rims screws and the tires do not move on the rims. If they did, I would see it in the bead being torn by the movement of the screws.
Is it the extra mass of the lock rings being so far from the center point of the axle?
kod99 is offline
Old 01-17-2010, 05:47 AM
Less sidewall movement not tire movement on the rim ....
But of course this is to a point if you dont have the power to lug the extra weight your just wasting your time, but by all means if you got the HP the beadlock is the ticket ..
Old 01-18-2010, 04:50 PM
SST4530
DYNO TECH
I thought about the bead locks for my wheels, but decided since the locks add about 8 lbs per wheel there was no performance gain by using them. It's been said every 10 lb of rotational weight is equal to 100lbs of sprung weight. So thats like adding 160 lb. to your car. Locks do look cool though! :wink:
SST4530 is offline
Old 01-19-2010, 05:03 AM
3 thousands difference back to back weld beadlock vs nonbeadlock same hoosier tire
Old 02-10-2010, 11:00 PM
SST4530
DYNO TECH
Can't argue with that. May be a bigger difference a SB than a BB?? :?
SST4530 is offline
Old 02-11-2010, 04:29 AM
I have no doubt if you dont have the HP/TQ to lug the added weight along they will be much slower. Them bad boys are heavy !
