motor mount question
DYNO TECH
I have a set of poly motor mounts for my 302 that i havent used will they work for my 406 smallblock?
they bolt up nice but im concerned with the height of them compared to the exsisting ones I have on my 383 thats in the car now.
going in the camaro
the mounts in question are energy suspension part # 31118R
going in the camaro
motor mounts
All chevy big block and small block mounts should interchange if you do not have clearance issues to deal with. So, if you have a '69 camaro with a small block and no fan shroud, it probably will not matter which mount you use. There are 2 different heights of factory mounts. Don't recall right now, but I think they are either 3/8" or 1/2" different in height. For example, a '69 big block Corvette uses the short mount. If you try to use the tall mount, the fan will hit the shroud and you will most likely have a hood clearance problem. If you do some research at on-line part stores, you should be able to figure out which mount (tall or short) came factory on your car. Again, it might not matter on your application.
Good luck, Dan
Good luck, Dan
It does not matter whether it's a 283 up to a 400. There are different heights depending on the frame mounts and what car/chassis they were meant for. If they are different than what you run you may run into pan clearance, header clearance, or bellhousing area clearance even if they bolt up. And shroud as mentioned.
