434 Camshaft clearance
I thought I had read somewhere that in a stock block you are limited to how much camshaft you can throw at it without hitting the rods even on a small base circle, does anyone know if this is true? What is the limit? Thanks, any info greatly appreciated!
It kinda depends on the rods you use and what some cam manufacturers call a small base circle. Some cam grinders call a .930 a small base circle and some call a .900 a small base circle. In most cases you're safe with a .630 to .640 lift. I had bullit grind my cam and it's a .870 base circle, i'm running a .689 lift with a set of Lunati Promod rods, but it's also in a Dart lil "M" block, a stock block has the came cam height.
Duration and separation angle will come into play as well. I've always been fine with .450 lobe lift, but it got a little tight after 278 duration. at 284 / 292 I had to pull .040 from the rods to get what I felt was safe clearance.
Mock it up before the balance work..
Mine is right in the danger zone, that why i ask them to grind it too an .880 BC which is not standard, but i'd seen the problem before.
