switching to alcohol help...
looking to switch our door car over to alcohol with out new engine combo, sonny's 565, 14.8 comp single dominator, 400 w/brake 2600lb car, anyway running a magna fuel large pump, #14 line from cell(rear) to pump, #8 to regulator. just wondering what I will need to change other than the carb ? thanks, Rob
Re: switching to alcohol help...
ask about the regulator with the Air bleed..you will need this for your electric pump to prohibit prerssure Creep or possibility of blowing carb seats out due to the high fuel pressure you need to run with the alcohol.....they can explain the way it works besides me trying to type a Book....
i know PRO- systems sells this regualtor for $75.00...you can also fab you one up if you know your stuff.
