Manual Tranny suggestion for 68 Camaro with 750hp
Old 08-07-2010, 05:18 PM
Swairlines
Default Manual Tranny suggestion for 68 Camaro with 750hp
Good evening all,
I'm looking for suggestions from all of you who have manual tranny experience. I'm looking to build a 68 Camaro that will host up to a 750hp powerplant. I'd like to get your opinions on a manual transmission that is able to handle such high HP output AND has a 5th or 6th gear overdrive.
Any suggestions?
Swairlines is offline
Old 08-08-2010, 08:32 PM
gearhead1011
gearhead1011's Avatar
It will make a lot of difference as to how you want to use the car. Will it be used only/mostly on the track or street? Regardless post this on http://www.umtrnorth.com/forums . You will get a lot more info on manual trannys on that site than anywhere else. You will have to be a logged in member to access the site.
gearhead1011 is offline
Old 08-08-2010, 09:58 PM
Swairlines
Thanks GearHead...
The 68 will be built up into a ProStreet styled street shredder. I have no interest in drag racing. I have a HUGE interest in closed course styled street racing. So the tranny is going to have to be able to handle lots of shifting to include both up-shifts for acceleration AND down-shifts to aid in deceleration and keeping the RPM's up.
Any recommendations would be helpful. Thank you.
Jeff
Old 08-09-2010, 05:27 AM
What is 'closed course style street racing' ?
Old 08-09-2010, 07:46 AM
gearhead1011
It sounds like you will need a synchronized street tranny. I'm more familiar with the drag racing type and not real "up" on road racing trannys. I believe Richmond and G-force produce a transmission that should do the trick. I don't know if either of them make a street box that will handle 750 hp but if you're not running slicks at a drag strip you will probably spin the tires before you apply enough torque to break one of them.
Old 08-09-2010, 03:17 PM
wmeabates
Check jericoperformance.com,Bill.
wmeabates is offline
Old 08-09-2010, 06:11 PM
traysvega
Might check with D&D on there magnum T56 6spd.Not sure of the H.P rating but 700 ft torque rating..
or better yet,the viper spec BA11 rated at 750 ft torque..
http://www.ddperformance.com/shop/pr...Path=107_92_94
http://www.ddperformance.com/magnum.html
traysvega is offline
Old 08-12-2010, 08:32 AM
Swairlines
Gearhead, wmeabates, & traysvega,
Thanks for the info and links. I'll look into it.
I'll get back to you guys on this.....
