worn brass dist gear
Old 01-21-2015, 02:30 PM
  #11
HiredGun7
Not my picture but this shows the idea perfectly. I use a triangle shaped file and cut the slot about .020" deep. Time the groove so the oil goes onto the gear right before it meshes with the cam.
HiredGun7 is offline
Old 06-04-2021, 01:51 AM
  #12
eerode
Banned
Originally Posted by scott0408 View Post
running a 421 sbc after a year of
Speed Test racing doing some work on it & found the dist gear worn not extremly bad but still makes me worry about it any ideas
. It's not uncommon. You can usually pick that up with a timing light is will show eratic timing when you check the timing. Hope this helps.
eerode is offline
Old 12-24-2021, 10:52 PM
  #13
bencomputernews
toi hieu ban
bencomputernews is offline
