very simple question for you experts
Old 02-14-2010, 05:23 AM
ejm
Default very simple question for you experts
holley fuel pump what is the actual fittings that go into the pump? an???? not that familar with the an fittings thanks
ejm is offline
Old 02-14-2010, 06:09 AM
kbartley
Default fuel pump
not sure which pump you have but a good many of the holley pumps take 3/8 NPT and then there are some that take 1/2" NPT.
kbartley is offline
Old 02-14-2010, 08:00 AM
ejm
its a holley blue electric
ejm is offline
Old 02-14-2010, 08:13 AM
MEMRACING62
MY HOLLY BLUE IS 3/8 NPT(PIPE THREAD)
MEMRACING62 is offline
Old 02-14-2010, 08:20 AM
bowhay
X2
3/8 npt
bowhay is offline
Old 02-14-2010, 09:44 AM
ejm
so any pipe thread 3/8 will work ? i have been using 3/8 brakeline any way to tie into that or just put a nipple on and put a rubber splice?
ejm is offline
Old 02-15-2010, 12:34 PM
kwkracing
Your asking two diff questions now. A 3/8 brake line will not fit a 3/8 npt, a pipe thread has a tappered thread pitch. Are you asking if you can use 3/8 brake line as the fuel line? Sure, if you attach some sort of 3/8 hose in between or find two 3/8 inverted flare bushings to put in ur pump.
kwkracing is offline
Old 02-15-2010, 01:53 PM
gnsrule
AN fittings are the tapered seal, streight thread fittings commonly used on the fancy red and blue fittings and anything also commonly reffered to as JIC.
gnsrule is offline
Old 02-26-2010, 01:32 PM
ejm
thanks for clearing up!!!!!!!!!1
ejm is offline
