Camshaft
Old 11-15-2008, 02:37 PM
hotrod1024
Default Camshaft
Just wondering if someone can help me decide which cam i should run.I have 2 cams both are in great shape.1 is an edelbrock 234/244@50 with 488-510 lift.308/318 advertised.Other is a crane cam 320/320 480/480 older but cant find much more info.it has 228/320 stamped on end.Im building a 4 bolt 350 60 over with a tunnel ram with 2 450s.Car is tubbed with ford 9 inch.Havent gotten heads yet but putting bottom end together.Th350 with stall, but exact stall not decided yet.I want a lopey to rough idle with good power.Not sure what other info is needed to decide which cam is better.Thanks for any info.Randy.
hotrod1024 is offline
Old 11-15-2008, 11:18 PM
poncholvr
id prolly go with the edelbrock cam myself ,and twin 500's or 600's
believe me the motor will like more fuel available rather than starving
get some edel heads there cheep enough for chevy's now a days
and use the best springs retainers,and valves instead of just the ones that will get you by
poncholvr is offline
Old 11-18-2008, 11:38 AM
hotrod1024
Thanks fo info.I found a set of procomp aluminum heads 202/160 i beleive 64cc i beleive, for 649 shipped.Is that a good deal.
Old 11-18-2008, 12:35 PM
jmarksdragster
jmarksdragster's Avatar
Run far away from the Pro-crap heads. Spend a little extra for as cast Darts, by the time you fix the issues you will spend more than if you had bought the Darts.
jmarksdragster is offline
Old 11-18-2008, 02:16 PM
hotrod1024
Have any idea off hand how much darts are or if anyone knows anyone with a set for sale reasonably.Thanks.
Old 11-18-2008, 02:45 PM
jmarksdragster
This is a good head for your combo with springs matched for your cam.
http://www.competitionproducts.com/p...er=10310010PK1
Old 11-18-2008, 03:12 PM
hotrod1024
Thanks Mark.Those are sweet,but a little out of my price range.Could someone maybe tell me what size i need.Runners chamber and such.I do know im looking for 202 160 valves but other than not sure.Thanks.
