4,400 HP !
Old 02-07-2013, 09:36 PM
  #11
bluedawg357
Originally Posted by roadkill2
I wanna see the Head!
Thats what she said.
bluedawg357 is offline
Old 02-11-2013, 01:44 PM
  #12
Scooterz
OK; forgive my ignorance here... but it is hard for me to comprehend this whole thing. MY question: in the first series of pics that Fla1976 posted- WTH is pic #2??? What is that thing... flux-capacitor?
Scooterz is offline
Old 02-11-2013, 01:47 PM
  #13
fla1976
fla1976's Avatar
Roller lifter.
Quote from Hot Rod "We dig the bolt-in lifter bushings, which make swapping them out a snap after you’ve nuked one. Drag Week Unlimited Class racers, are you listening? By the way the lifters have wheels that are over one-inch in diameter".
fla1976 is offline
Old 02-13-2013, 05:52 AM
  #14
roadkill2
Still want to see the head(s) . .
And if the Lifters have a 1" dia. Roller follower, what the hell does the Camshaft look like? It's gotta have lobes that resemble the counterweights on a SBC crankshaft . . I understand the need to cut bearing speed and increase the loading at the lifter (More valve seat pressure) but a radius like that isn't conducive to following a quarter inch radius on the ramps of todays long duration .800"+ lift "square lobed" cams, one would think . .
But then I was never very good at driving trains . . .
roadkill2 is offline
Old 02-13-2013, 04:06 PM
  #15
The cam journals have got to be humongous ! 3" any way... :shock: :shock:
Old 02-14-2013, 05:53 AM
  #16
roadkill2
Yeah, I went back and looked at the picture of the block after I popped wise . . I'd guess that they're closer to 4" in diameter because they're actually bigger than the mains . .
Still, when you build a bigger lifter, you just create more reciprocating mass that has to change direction at high speeds and tremendous spring pressure . . so then you have to increase valve spring pressure, stronger rockers, bigger pushrods and more expensive one piece valves . . It's kind of a vicious circle . .
All the NASCAR guys are going the other way . . Little bitty cam lobes, little flat tappet lifters, skinny pushrods, and really high rocker arm ratios, 1:8/1:9 with 125# of seat pressure . . Dunno who's right, but their engines are built to go about 550 miles, while a drag racing engine spends more time being warmed than it does racing.
I guess us drag racers like kicking the tiger's ass more than tickling a mouse . . 'spose?
