My brain is killing me!
Old 09-03-2007, 07:21 PM
utahchargerzz
Default My brain is killing me!
I have a superchaged f/i 383 stroker. w/Accel DFI. the motor ran like a raped ape. But I noticed while I started checking things out that the timing showed 125 degrees advance. The motor was set with this firing order 3-8-4-1-6-7-5-2 it was set up by Dan Sells chicago. I've tried several times to get in contact with him with no luck. So I'm looking for somebody that may have an idea of how this set up is accomplished to work. I have the dual sync distributor properly installed. But it's still not right...................HELP Dan
utahchargerzz is offline
Old 09-04-2007, 07:01 PM
et7333
Go to SPEED TALK in the engine tech section and ask the same question
et7333 is offline
