SLOW 1-2 SHIFT ON TH400
Old 01-31-2008, 10:44 PM
  #41
SST4530
DYNO TECH
TH250 and TH350 are almost identical units.
SST4530 is offline
Old 02-01-2008, 06:17 AM
  #42
olds48
I've always been amazed at the durability of stock "junk".It really holds up alot better than the aftermarket would like you to think.
olds48 is offline
Old 02-01-2008, 08:46 PM
  #43
jmarksdragster
jmarksdragster's Avatar
Originally Posted by olds48
I do run a filter,not a screen.Cheap generic filter at that.Never crossed my mind. Cepxx,I always figured a 2-speed would kill my 60'.Then one night I accidentally took off in second gear(manual v-body),60' was the same,et was the same,picked up 4 mph in the 1/8!!!Gets you thinkin'....
A PG will ALMOST always be faster than a 400 with the correct converter.
There are exceptions, but for most cases the PG will win out.
jmarksdragster is offline
Old 04-15-2008, 05:17 PM
  #44
olds48
Well..finally found out what was causing the lazy shift.My pump was worn so bad that the rings couldn't seal.Low pressure.Actually broke one of them.Took out 1st and 3rd clutches,2nd looks like new :shock: Just goes to show that if you don't know what you're doing,take it to the tranny guy.You CANNOT beat a man at his own game.
olds48 is offline
