tongue weight
Old 02-24-2009, 05:38 AM
john858
Default tongue weight
how do u or what is the best way to figure the tongue weight on your enclosed?thanks for any help,john
john858 is offline
Old 02-24-2009, 06:14 AM
3dracing
Go to a set of scales and weigh the tow vehicle, then go back with the trailer and have just the tow vehicle on the scales and see what the difference is.
3dracing is offline
Old 02-24-2009, 06:50 AM
load up your junk into the trailer first as if you were going racin'.
Old 02-24-2009, 07:20 AM
jtortorete
Default Tongue weight
John
Tongue weight as I know it is the weight that the receiver sees from the trailer. Reese hitches with weight transfer bars are much different.
With the trailer loaded go to a truck scale, put just the tongue on the scale using the support jack at the front of the trailer tongue. Detach the truck and drive it off the scale. Lower the tongue to the height of the tongue when attached to the truck. then get the weight from the scale operator.
If you do not have a front jack, you will need to block the tongue up at the point where it attaches to your tow vehicle.
You will need to find a business that will allow you to tie up their scale for a bit.
jtortorete is offline
Old 02-27-2009, 07:15 PM
THERATTLER
THERATTLER's Avatar
I don't know how much it weighs but when my wife's tongue talks , I jump. :lol: :lol:
THERATTLER is offline
Old 02-27-2009, 07:41 PM
OH GAWD !! The visuals THAT congures up !!
ROFLMAO I'd say it weighed a couple of ton to make YOU jump :shock: :shock: :shock:
Old 03-08-2009, 09:22 AM
THERATTLER
THERATTLER's Avatar
YOU said that NOT ME :lol:
Old 03-13-2009, 07:48 AM
gibsonjamesj
I've always heard 60% front 40% rear from the first axle, this should give you the correct tounge weight.
gibsonjamesj is offline
