Weight Distribution
Old 09-19-2008, 03:18 AM
  #11
BillyShope
Default Re: RE
Originally Posted by ssym
...wait until I get a couple launches under the wheels?
Steve
Why? You know what's going to happen.
BillyShope is offline
Old 09-22-2008, 01:39 AM
  #12
ssym
Default Re
Maybe I should have expressed my lack of knowledge and experience with chassis and four link....
I am not sure what will happen the first time I launch.
How do I adjust the corner weights without cutting metal and welding it to the other side? Will "light corner" shock adjustments do the job?
And on a second note, does anyone have suggestions for first time launches? Half RPM, transbrake, half throttle? I like the balls to the wall method, but I'm trying toget a little smarter as I get older.
Thanks in advance,
Steve
ssym is offline
Old 09-22-2008, 03:29 PM
  #13
Default Re: Re
Thanks in advance,
Steve
I'm not saying it will work for you but, i adjust everything nutural, then put a couple turns on the right rear coil, then use foot brake so it doesn't leave too hard or point the front end in the air, that way i still have some control just in case it does pull one way or the other.
