pushrod length
pushrod length
i am building a 406 sbc with .900 small base roller cam. i have .100 longer pushrods and i don't have an adjustable pushrod with the .100 longer pushrods the rockers are not touching valve tip the heads are AFR 210 AND I'VE TRIED 2 SETS OF ROCKERS AND BOTH SEEM TO NOT CLEAR THE RETAINER WILL THE LONGER PUSHRODS CORRECT THE ROCKER PROBLEM? WHAT LENGTH DO I NEED .150 OR .200 LONGER NOBODY SEEMS TO WANT TO TELL ME I DON'T WANT TO HAVE TO BUY MORE ROCKERS. I JUST NEED HELP ON PUSHROD LENGTH AND IF THAT WILL HELP WITH ROCKER ISSUE.ANY HELP THANKS!! using fel-pro 1034 head gaskets and 13.5 comp. forged pistons
What size valve springs are on the heads :?: Also they probably came with .100 long valves so you may need .200 lg push rods. You'll $'s ahead if you just buy an adjustable pushrod for $15.00 and do the measurement, all cam company's sell them and so does Manton.
Thanks, i'm going to run it this weekend. .200 may work, but if they don't you're out $80.00 to $100.00, it's just a better investment to buy the adjustable push rod., and then you'll know for sure what length you need.
