Power est for a 505bbc
Old 04-15-2009, 07:20 PM
obsessedtruck
Default Power est for a 505bbc
Kinda curious before i dyno this thing to get a genearl idea on where it might be at.
505ci
4.25str
4.350 bore
9.6CR
cast ovals,int-320ish@ .600"
RPM intake
850quick fuel
224Int,234E @ .050
.540int, .557 exh lift hyd flat
110center
2" hooker super comps.
Not to shabby for a dually motor. :wink:
obsessedtruck is offline
Old 04-15-2009, 08:53 PM
radicalz
:lol: ....obsessed kind of limited with those heads and compression ratio...if it makes 500hp i'll be surprised...but will make up for it with torque...my guess maybe 400hp an 500ftlbs of torque...not too bad for a tow vehicle...all that tq will be down low which is good....
radicalz is offline
Old 04-15-2009, 08:55 PM
michael1
I would say somewhere around 450-500. Will you let us know after you dyno it? Thanks
michael1 is offline
Old 04-16-2009, 04:06 AM
obsessedtruck
It'll be on a the chassis dyno at the shop. Previously it made 340 at the tire. That was at a 476ci with the diffances being a tad smaller cam like 224 e and i @ 50. Be intersesting
Old 04-16-2009, 08:42 AM
tcarda
I thought you had rectangle heads on that??? I think it will be in the 540-550.
On a side note one of my old "stock" motors had some port work done to the 781 heads, 9.75:1, hydraulic camd and made 576 hp on Wheelers dyno....on 92 gas.
tcarda is offline
Old 04-16-2009, 10:08 AM
cncmotorsports
We just did a 496 with this same set up, dart 308 heads, engine made 555 hp and 615 torque with quick fuel 850.
Compression was 9.0:1 had flat tops.
Cam had just a little more duration, around 230 @50 but lift was only .510
cncmotorsports is offline
Old 04-16-2009, 04:47 PM
obsessedtruck
The heads are a closed chamber factory head old 206 casting. Its got some very extensive port and chamber work to get valves unshrouded. They CC at 110.
Old 05-16-2009, 10:01 AM
obsessedtruck
finally got to chassis dyno the 505ci duallly today. Before it had 340hp , 365tq at the wheel. Up to 370hp and 445tq at the wheel. The cam is a 224int , 232 exh at .050. Its really fun to drive.
Old 05-16-2009, 12:32 PM
mopar1968
mopar1968's Avatar
Blown up or Not :?: :?: Lucky if it get's out of the driveway :!: :!:
''JUST MY TWO CENT'S WORTH''
http://www.racingjunk.com/profile/163312
mopar1968 is offline
Old 05-17-2009, 06:00 AM
tcarda
That will be nice for pulling your trailer with this summer.
tcarda is offline
