carb prob ??
carb prob ??
i have a chevy 413 and has a 750 hp holley carb and the problem we are having is it will drop rpms after the temp gets to 180 degrees in gear only but runs perfect till we get up to 180 any advice on this thanks or if u need more info will let u know
when in gear and u push throttle going up against converter and let off of throttle drops rpms down to around 400 only does it when temp gets to 180 other than at that temp it dont drop rpms thanks for any help u can give
droppin idle speed
don't know if you have a spacer under the carb to isolate from the heat..might help. I have seen the fuel in the carb heat up and expand and dribble from the boosters and drop fuel into the engine..essentially causing a flooding situation. Look into the carb when the idle is dropping. Watcha see?
