VALVE ADJUSTMENT 4/7 SWAP CAM
The exact same way you adjust them on any engine. the 4 7 swap has nothing to do with it...unless you use a method like "Bring number 1 to TDC then adjust intakes on these cylinders.... etc
Just adjust each valve when the lifter is on the base circle.
When the ex starts to open, adjust the intake. When the intake has opened completely and is on it's way closed, adjust the exhaust.
Originally Posted by jrthone
That answer hasnt realy given me a method. I have always done it starting on TDC etc. Wats the best way to do it. and the quickest
Just lash them the way you've always done it. WITH the new firing order, you'll be just fine. As long as the lifter is on the base circle, for the valve you are adjusting, everthing will be just fine.
ok thanks. all that info was no help at all. In the above 8 threads i did not get step by step method. I am new to this and this has wasted alot of my time. If ANY 1 out there has a STEP by STEP Method it would be greatly apreciated.
