383 cam
Old 12-26-2009, 12:14 PM
et7333
Default 383 cam
What FLAT TAPPET,NOT ROLLER, cam would you use with this combo:
383 sbc,13.6-1,dart iron eagle 215 platinums,2.05 1.6 valves bowl blended and port matched to a 2925 super victory,alky 810 carb,power glide,4.56 gears,4800 convertor,3100 lb car.This is a 1/4 drag car.
et7333 is offline
Old 12-26-2009, 05:49 PM
Pwmax
Not to be a dick, but dude, how many websights are you going to ask the same question in multiple posts, over and over? What kind of answer are you looking for? About 50 different guys have given you the answer for.
Basicaly, put all the cam cards, put them in a hat, and pick one. thats about as easy as it is. 260ish at .050, .600 ish lift, 106 lobe sep, your good to go. here is a Lunati cam part number that works well.
Cam number 40156 Grind number M264-269. Its 264-269 at .050, .570/592 lift, 106 lobe sep, ground 4 degrees advanced. Use a 1.6 intake rocker, 1.5 ex. rocker. That cam will work well
Frank
Pwmax is offline
Old 12-26-2009, 06:31 PM
Pwmax
Actualy, the cam Zipper suggested, on the FLAT TAPPET SPECIALIST post, would work better yet. Use the same 1.6/1.5 rocker
Pwmax is offline
