INTAKE QUESTION ON REC PORT BB2X HEADS WITH OVAL VICTOR
RECENTLY BUILT A 565 BBC WITH A 400TH AND 5200 CONVERTER . IT IS IN A 84 MUSTANG . BEST RUN AT LAPEER DRAGWAY IS 10.02 WITH A 1.48 60 FT .
MY QUESTION IS WHAT IS THE ULTIMATE INTAKE TO RUN ON THIS COMBO . IT HAS 14 TO 1 COMP 280 290 @50 800 800 SOLID ROLLER ON A 112 . 4.600 BORE 4.25 STROKE AND 6.535 RODS . WE AR RUNNING BRODIX BB2X HEADS ORIGINALLY A REHER MORRISON HEAD BUILT BY BRODIX FOR REHER. WE ARE RUNNING A VICTOR OVAL PORT INTAKE GASKET MATCHED TO OUR REC PORT HEADS .
WE RUN BEST SHIFTING AT 7000RPM COMING OFF TBRAKE AT 5500. WE ARE RUNNING A 1150 DOMINATOR CARB JETTED AT 97 SQUARE WITH NO PV .
THE OWNER AND BUILDER IS THINKING OF RUNNING A PROFILER INTAKE BUT I THINK MAYBE A SUPER VICTOR WOULD BE BETTER.
ANY THOUGHTS OR PROOF GUYS WOULD BE HELPFUL.
HE RUNS 137 BEST MPH AT 10.02
THANK YOU
THANK YOU
i just had a 565ci built with bb2 heads ( with ton of hand port work) i have a victor 454-r matched..15 to 1 compression..
my engine guy said my 565ci will have more torque with the heads and intake i used..this was OK with me since i run the 1/8...TQ IS kING in 1/8th...
i used this victor cause i had it matched to the heads already plus it has a ton of Plentum work done.... i have heard GREAT things about the Profiler..but some say its for bigger engines 600+ci or if your running an exotic head on your 565ci like a 12 degree profiler etc...I DUNNO :?: ..I know what their web-site says
Just curious..what does your Mustang weigh ?..My camaro (3100lbs) with a 12 to 1 compression 511 ci ran mid 5.90's in 1/8.. which should be in the lower 9.60's in 1/4...
with this new 565ci if i do not run 5.60's in the 1/8 and 9.20 range in 1/4 i will be disapointed. ( all motor )
Curtis can tell you a little more on this subject i would bet.
WE FIGURE IT WEIGHS ABOUT 3000 BUT THAT ALL GUESS. WE HAVE YET TO WEIGH IT.
WE NEED TO GET TO BETTER TRACK AND TEST IT LIKE MILAN.
I STILL FELL THAT A OVAL PORT INTAKE PORT MATCH IS JUST A PROBLEM. I THINK THE ENGINE STRUGGLES TO PULL ENOUGH AIR THRU INTAKE AT 6000 + RPM.
HE HAS PLENTY OF PORT SPEED DOWN LOW BUT WITH 565 CUBES IT SHOULD SUCK ALL THE VOLUME OF AIR IN THE SMALL OVAL RUNNERS OUT.
IF IT WAS A 454 WITH SMALL CAM AND BIG REC PORTS ID SAY LET RUN AN OVAL PORT BUT THIS ENGINE HAS THE CUBES TO RUN A NICE REC PORT INTAKE.
WE ARE CURRENTLY LEANING ON THE SUPER VICTOR CNC VERSION.
THANK YOU
THANK YOU
The super victor is great. The Brodix 2001 is also a good one. I thought you had a oval port intake like the profiler for conventional heads (oval) which is a very large oval. I like all of these intakes and my experience on the first two has been almost identical. I lean toward the Brodix if the area under the carb is ported just below the cast in spacer. It sounds to me that you do have some kind of a problem tho, that thing should be shredding the tires and running low 9s. I have almost the same engine but in a 2400lbs car and it runs 5:teens in the eighth with a 4:30 gear and a 32inch tall tire. It has seemed to me in the past that when a conventional head gets to big that they really stop giving anything back in return. I am about to try the 3x oval cnc Brodix in the next few weeks to see if they perform better than the bb-2 that are on it now. They are hand ported but they are only 340cc.
I got a out of the box stock 454R with the 4150 flange on my 540..I use a 1050 dominator so it hasd the funel adapter. It is 13 to 1 with a smaller cam than you have, with out of the box 2X heads ..works well.
