cooling in the pits
Old 11-30-2008, 02:50 PM
  #21
sg1586
Did you guys notice what filter is on that glide???
I have been using one of them for a wile now :mrgreen: :mrgreen:
sg1586 is offline
Old 11-30-2008, 05:32 PM
  #22
us7race
Barry what kind of filter is it?
us7race is offline
Old 12-01-2008, 08:47 AM
  #23
sg1586
Jody it is a Mopar filter with a special made adapter...It works great and alot more filter area....
You can get them from TSR
:lol:
sg1586 is offline
Old 12-02-2008, 04:01 AM
  #24
sg1586
Originally Posted by us7race
That cooling pump also needs the ATI Supercase :shock:
sg1586 is offline
Old 12-09-2008, 12:34 AM
  #25
I like the nitrous idea, very cool and much cheaper than buying a fancy pump and ATI super case> maybe nitrogen would be cheaper than NOX though. Cp
Old 01-03-2009, 05:16 AM
  #26
shawnp
I think its ATI who makes the pump you are looking for but its $800.00
Saw it at PRI. Was told if you don't have 20-30 mintues to cool, then you are wasting your money. The design feature is not for your normal hot lapping bracket car. I think the set up could be duplicated much cheaper.
shawnp is offline
Old 01-20-2009, 02:46 PM
  #27
shoedoos
Plumb the lines to the side of the pan using some quick release fittings with one-way valves from a hydraulic shop, use an old Melling oil pump with a drill attached to it and run the trans fluid through a coil of copper line sitting in an ice box - cools a race TH400 in 10 minutes to completely cold....and you can also keep the beer cold if the ice box is big enough....
shoedoos is offline
Old 01-20-2009, 04:23 PM
  #28
We use Weldon high temp pumps for our differential cooling system. The model 9200 is what you want along with a cooler from Summit or Jegs or.....
http://www.weldonracing.com/product/..._Oil_Pump.html
On sale here;
http://www.srmotorsports.com/Weldon_Fuel_Pumps.html
Cooler with fan here;
http://www.jegs.com/p/Perma-Cool/744433/10002/-1
Old 01-20-2009, 06:52 PM
  #29
us7race
Wouldn't that only cool the fluid in the pan, not the trans and converter?
I think it may help but I think the real heat is in the converter.
us7race is offline
Old 01-20-2009, 07:00 PM
  #30
mopar1968
mopar1968's Avatar
I use nitrous to cool mine does the job quickly :!: :!:
mopar1968 is offline
