Methanol and CR
Old 03-03-2009, 10:54 PM
jrthone
Default Methanol and CR
Whats the lowest comp ratio you would use for a 632 BBC on Methanol( Enderle bird on a tunnel ram). My engine builder has just built mine with 13.6-1 . Is this too low for methanol????????
jrthone is offline
Old 03-04-2009, 01:48 AM
Drtmod5
You're in good shape to use it.
Drtmod5 is offline
Old 03-04-2009, 03:35 AM
suicidebomb
Go for it !
suicidebomb is offline
Old 03-04-2009, 05:26 AM
13:1 will be fine, I've ran it on 10:1 motors before and works fine all in the tune up
Old 03-04-2009, 11:03 AM
desoto30
X2 had 9.8-1 single 4 solid roller "learner"SBC 1.27 60ft 5.75 117 660 & 9.26 141 1/4 Oh 1690lb race weight went as well as we could have hoped with still more in the tune
desoto30 is offline
Old 03-06-2009, 09:49 PM
Alcohol, luv's compression but wiil run anywhere, you got what you got so stay with it, idealy 13.5 plus for more power, but you'll gain something.
Old 03-08-2009, 04:42 PM
ashbros
I've ran it in 8.5 /1 ratios but I sure love the crackle at 18/1
whop pa pop a pop pa pop
ashbros is offline
