engine lacks power
Old 10-29-2009, 07:09 PM
bowhay
Default engine lacks power
383 sbc
fuel pump went out a while back so the truck sat for about 2 weeks while waitin for the replacement
got the new one put it on and the motor acted like the carb was out of tune and the timing was wrong......neither of witch had been changed
pulled the pluggs and they were burnt white for runnin to leen, figured it was cus the fuel pump wasnt gettin enuough gas to the carb n it was runnin lean at high rpms, so i take some emery cloth n cleas em all up.....
seems to fix the problem but the truck is lacking alot of power now, and is acting very weird....randomly it will act like it is fooding horribly or not gettin any spark, very irratic idle and have to give it alot of gas to keep it goin, then all the sudden it runs right again....could this be that there is an issue with the stock ditributer or wat??????
bowhay is offline
Old 10-29-2009, 10:19 PM
rob41willys
More info? What kind of fuel pump? Carb? If the only thing that was changed was the fuel pump then what may have caused this problem. Debris in the fuel line? did you use teflon tape on the fitting? Etc.
rob41willys is offline
Old 10-30-2009, 03:13 PM
Scooterz
X2.
Does it have a vacuum advance??? vacuum leak? Etc...
Scooterz is offline
Old 10-31-2009, 05:49 AM
TheRabbit
TheRabbit's Avatar
If it's having a hard time running at idle it may not be the fuel pump. It doesn't take much pump to keep it idleing. Of course make sure the bowles are full. I would also check the distributor cap and rotor button. Had that happen to me this summer.
I would pull the carb apart and check everything really good.
and I agree with
TheRabbit is offline
Old 11-15-2009, 07:15 PM
rooski67
Default no power missfires
had the same thing happen to me. look for trash in the fuel bowl. when trash gets stuck in the float valve it will cause the bowl to overflow and flood . can barely keep it running especially at idle. jack it a couple of time, trash gets flushed out runs great until it happens again. check it out. Or you may be over powering the float valve with your new fuel pump. (max 8 lbs)would act the same way.
good luck.
rooski67 is offline
Old 11-17-2009, 06:01 PM
onedragracer
Default Re: engine lacks power
Originally Posted by bowhay
383 sbc
The ditributer might be fooding Maybe you need to "cleas" it again :shock:
onedragracer is offline
Old 11-26-2009, 08:48 AM
mopar1968
mopar1968's Avatar
Must be a ''chebbie'' enough said :!: :!:
''JUST MY TWO CENT'S WORTH''
mopar1968 is offline
Old 11-26-2009, 10:01 AM
bowhay
yea it is a chebbie lol
but i got it all fixed a couple of weeks ago, turns out it was the distributor, i bought a mallory mechanical advance and a msd coil and it fixed it right up
runs a heck of a lot better now too
thanx for yalls help
bowhay is offline
Old 11-26-2009, 11:15 AM
mopar1968
mopar1968's Avatar
Bowhay-- I just had to :!: :!: Have a great holiday :!: :!:
Old 11-29-2009, 02:09 PM
bowhay
u too mopar
bowhay is offline
