700r4 vs 4l80e vs 400th vs big cam
Old 07-02-2009, 03:11 AM
Timmyboy86
Default 700r4 vs 4l80e vs 400th vs big cam
i have a 37 chevy with a 400 small block and need to buy a transmission i need 3500-4000 stall so i was wondering if i should even be looking at overdrive
Timmyboy86 is offline
Old 07-02-2009, 08:19 AM
oldandtired
oldandtired's Avatar
I am thinking this is a street car, so everything depends on your rear gear ratio.
You have a crusing speed (RPM) and a highway speed (RPM).
A loose converter builds a lot of heat if you do not run enough RPM to get over the stall.
Dave
oldandtired is offline
Old 07-02-2009, 02:47 PM
kwkracing
If your running a big gear in the rear a od tranny would help put at highway speed, but if you have a 3.73 or 4.10... i would not be running it in od unless you plan on cruising at 90+ mph on the highway when the convertor is locked at 4g.
I would try getting a friendlier cam, going with od if you are planning on Highway driving.
If you just want to play put a 3 speed.
kwkracing is offline
