487 sbc heads
Old 08-01-2012, 08:42 AM
hotrod1994
Default 487 sbc heads
are the 487 sbc heads any good looking for a good flowing head on the street there the 487 not the 487x
thanks-logan
hotrod1994 is offline
Old 08-06-2012, 05:51 AM
cncmotorsports
The 487 and 487X were good for there time. Still nothing close to a Vortec head, or anything aftermarket.
cncmotorsports is offline
Old 08-06-2012, 11:59 AM
hotrod1994
ok what has to be done to a vortec head to be able to take 550 lift spring ? without running the expensive comp beehives
Old 08-06-2012, 03:48 PM
fast75vega
just need to have them machined. i believe they can only take up too a .460 lift stock. comp cams sells a tool you can chuck up in an electric drill and do it yourself if you feel the urge :wink:
fast75vega is offline
Old 08-06-2012, 04:58 PM
hotrod1994
ok thanks
Old 08-07-2012, 05:30 AM
cncmotorsports
We completely re-machine the head to accept whatever cam lift we are using, guide and spring pocket.
Old 08-07-2012, 07:31 AM
bluedawg357
Is it worth machining vortec heads to accomodate lift above .500'' ? I've read that they don't flow any better past .500'' lift, is that true?
bluedawg357 is offline
Old 08-07-2012, 02:34 PM
cncmotorsports
Yes it is worth it if this is what you have to use, or your class rules mandate it. Other wise aftermarket heads are a much better solution.
Old 08-23-2012, 04:15 PM
RM1
Default 487 heads
for time and the money u spend on all add ons for the vortec ( valves springs covers intake oh yea they crack easy take your cash and buy a set of GM 292 turbo heads there the same as a dart 2 right out the box
RM1 is offline
RM1
Default 487 heads
RM1 is offline
