Blown Head gasket 302 with a 671
Old 09-17-2012, 04:56 PM
Fairlane671
Default Blown Head gasket 302 with a 671
I have a blown head gasket on 1976 sbf 302 with a 671. The block bored 30 over. What size head gasket do I need and what is the best? Copper? I am running the boost 6-8 psi it's 18% under driven. I need a model #.
Fairlane671 is offline
Old 09-17-2012, 05:36 PM
joe2412
stick with a felpro series head gaskets esp. the black type gaskets / what is your compression numbers at also what is your fuel system like just make sure you didn't run lean and blow the gasket that way as well good luck joe g 8)
joe2412 is offline
Old 09-17-2012, 06:00 PM
TS1955
Depending on what thickness you want...You can go with a cometic C5511-xxx gasket and be good to go.
TS1955
TS1955 is offline
Old 09-18-2012, 06:59 PM
Spurger
Blown head gasket on 1976 SBF 302 Australia
Head gasket leak test then maybe need
Replacement
Spurger is offline
Old 09-26-2012, 06:38 PM
maxpower671
X2 good advice! i like the felpro 1003 gasket for SBC, use something similar if you can...and make sure your fuel and fuel system are up to the task
maxpower671 is offline
