what did i do wrong ? where is my problem?
Old 11-15-2011, 01:18 PM
hotrod1994
Default what did i do wrong ? where is my problem?
76 camaro 3500 lbs
350 stock bottom end as far as i know it came with car and i rebuilt the top end
9.3:1
477/477 cam and 268/268 duration
1.94/1.5 heads
edelbrok torker intake holley 750 (kind big)
should make 300 hp atleast sounds like 350-400
th350
2000 stall
3.73 gears
with m/t 29/12.5/15 sprotsman pros
my problem is its a complete dog it wont spin the tires at all where should i look for my problem im not sure if trans and tourqe converter are good they cam with the car and we test drove it with the vaccum modulator not hooked up im not sure if this make a diffrence or not i know the tires are big but the motor sounds great rev's up nice
im willing to change the gears and such to get me going just looking for suggestions but building another motor is out of the question im on a tight budget
any help is appreciated
thanks logan
hotrod1994 is offline
Old 11-15-2011, 02:53 PM
spib
a loser convertor, say a 3200-3500 would help a lot and some deeper gears for sure
and a properly tuned 650 dp carb
that all would help a lot
spib is offline
Old 11-15-2011, 03:17 PM
hotrod1994
deeper gears as in higher? i was looking at 4.56's or 4.88's it gonna be a street car mainly might take it to the track once in a while so im not worried about running out of rpm's at the big end
Old 11-15-2011, 03:18 PM
curtisreed
curtisreed's Avatar
Since you did not build the bottom end, did you check the cam to make sure it was degreed right? Did you do a compression and leak down test? Have you verified the timing pointer? Just some stuff that can really kill power. It may not set the world on fire with what you have but you should at least be able so spin the tires.
The gears are fine just not ideal if just a race car. The carb is fine also just maybe not ideal.
My 2 cents.
curtisreed is offline
Old 11-15-2011, 03:43 PM
spib
yes some 4.56 gears, my wife has a 67 c10 shortbed, full street truck, 4,000lbs or more, has a worn out 355 my old motor all stock except 470 lift cam, has 3500 convertor and 4:56 gears, has hei and a 700 dp carb runs 13.80-13.90's and has ran a best of 13.71
spib is offline
Old 11-15-2011, 04:30 PM
fast75vega
whats the over all timing set at ? i think a 650 carb and 3000 or higher converter will help :wink:
fast75vega is offline
Old 11-15-2011, 04:37 PM
482
Just FYI Logan,
Actually, the 4.56 and 4.88 gears are lower than the 3.73
482 is offline
Old 11-15-2011, 06:10 PM
hotrod1994
i know there numerically high but actually lower
Old 11-15-2011, 06:12 PM
hotrod1994
how should i degree the cam i just lined the dots up on the timing chain and put the cam
how should i go about degreeing the cam ive never done it before
Old 11-16-2011, 03:38 AM
curtisreed
curtisreed's Avatar
This is instructions on how to degree a cam. You will need the info on the cam to do it though.
http://www.cranecams.com/uploads/instructions/803.pdf
