which cylinder heads for a 421
Old 09-05-2011, 06:34 AM
scott0408
Default which cylinder heads for a 421
wondering which cylinder heads i should use for my 421 i have a set of track 1 heads but the intake runners are small.for the cost of porting i could buy a set of heads that will flow
scott0408 is offline
Old 09-05-2011, 07:58 AM
jmarksdragster
jmarksdragster's Avatar
If you want a quality 23˚ head call Chad. He can set you up with the castings and runners that will suit what you have best, and the best head if you want to maintain your current rocker hardware.
http://www.SpeierRacingHeads.com/
If you want something better such as 18˚ or 15˚ heads, SB2's, or some other higher end head give Curtis at Race Flow Development a call.
http://www.raceflowdevelopment.com/
jmarksdragster is offline
Old 09-27-2011, 07:49 PM
weingartnerce
Default Re: which cylinder heads for a 421
It depends on how much someone charges for porting, for what I charge to port heads porting your heads is more economical.
Eric Weingartner
weingartnerce is offline
Old 09-28-2011, 05:57 AM
hink
We have a pump gas 421 in shop and are going to use the AFR 220's and we are looking for a low 600 number on the dyno.
hink is offline
Old 09-28-2011, 01:53 PM
markdunlap
Default Which
I built a friend a 13:1 421" SBC and used PRO TOPLINE/RHS 235 aluminum heads with no porting. .690" lift cam.
At 2850# it runs 5.90s in 1/8.
You almost need offset rockers on intake valves with these heads, but with adjustable guide plates you can manage no offset if you accept a slight off center on the valve stem. No problems in 2 seasons.
markdunlap is offline
Old 09-28-2011, 04:12 PM
TheRabbit
TheRabbit's Avatar
Go for the SB4.1 heads!
http://www.cferacing.com/?pid=69
TheRabbit is offline
Old 09-29-2011, 02:46 PM
cncmotorsports
Depends on your Budget, but the AFR 220s would be our first choice
cncmotorsports is offline
