Afr head stud problem
Im building a 406 sbc with afr heads with comp double valve spring the outside and inner most exhaust head stud bolt fit but its semi impossiable to get a socket on it ive milled down and grinded one to fit but it doesn't have the strength anymore i had to take so much out i know afr sells resized bolts for just those holes but wondering if anyone had an idea so i dont have to wait till mid next week to get the motor togther
Here is a site to calculate the torque difference Zip talked about. There is an explanation and calculator.
http://www.engineersedge.com/manufac...e_wrench_1.htm
I tried a set of crowfooted and they don't solve problem the nut had to drop down into a sleeve almost i'm thinking of just running down to a fastenal store and see what if they have a nut with small diameter but same thread
Has anyone ordered the "Abbrivated" nut that afr sells on there site i just want to make sure someone else has tried them before i was going to cal afr monday am but im on the east coast and they're based out of california just be easy to know if they worked for anyone else
