SCARRY RIDE, 1/4 mile steering problem
Old 04-03-2011, 08:09 AM
im18tid
Default SCARRY RIDE, 1/4 mile steering problem
67 camaro, 1/4 mile run, running 11.4, 119 mph. I have to steer the car to correct for constant fishtailing through the entire 1/4 mile. Now I know the tires are not spinning all the way through. Running 10 inch street slicks, GM 12 bolt 3.73 posi gears on standard 67 Camaro suspension with traction bars. I have the welded in subframe connectors. What are the various possibilities to check and in what order?
im18tid is offline
Old 04-03-2011, 09:13 AM
mopar1968
mopar1968's Avatar
What kind of rear tire's :?: How much air pressure :?:
Mark
mopar1968 is offline
Old 04-03-2011, 02:58 PM
Check the 'U' bolts on the rear end as well as EVERY fastener in the rear suspension along with bushings for slop. Wouldn't hurt to check the rear end 'square' with the chassis. Also check wheelbase side to side.
Old 04-03-2011, 02:59 PM
Default Re: SCARRY RIDE, 1/4 mile steering problem
as Mark said..check the air pressure simple things 1st...also sounds like your chassis is definatley not loaded at that point...example my nova will move around on you without Nitrous than with Nitrous..its the way we have the 4 link set up....this is totally different set up then you have but same weight transfer/chassis loading principle.
Your next step is to get the chassis loaded...I have a stock 69' camaro leaf spring car with slapper bars,weld in sub frame connectors( all the sub connectors do is resisit the car from twisting)...has a run a 5.84 @130 mph and very stable.
to make it work we placed a lot of pinion angle in the car and placed some moroso trick springs on the car..so the front end has a lot of travel ( soft )..so it tranfers weight real quick off the line and stays transferred to back tires as long as you have it under a full throttle..
Old 04-03-2011, 04:16 PM
mopar1968
mopar1968's Avatar
I run Hoosier slicks, wrinkle wall and if i drop below 10 psi my car will want to wiggle down track :!: :!: It is a ladder bar car with coil overs :!:
Mark
Old 04-03-2011, 06:23 PM
outlaw256
i have a street car that does or did the same thing.mine was a 2 problem hit. one was one slick had more air than the other and after a corrected that it wasnt as bad but still there.found 2 loose u bolts.fixed that and good to go. let us know what you find.
outlaw256 is offline
Old 04-04-2011, 11:13 AM
et7333
I'm curious are you using a radial tire in the front and a bias ply in the rear?
et7333 is offline
Old 04-05-2011, 03:21 PM
ballsout1
front control arm bushings can cause some narly handling also
ballsout1 is offline
