402 heads on 502 block???
Old 01-14-2011, 04:34 PM
Byrd67
Default 402 heads on 502 block???
I was building a 402 BBC and just put some money in the heads but just came across a 502 BBC and was wondering if the 402 heads will work on the 502?
Byrd67 is offline
Old 01-14-2011, 05:13 PM
contagious
Default HEADS
Mark 4 heads will work on a gen 6 block,if that's what your asking.Need to check the numbers and see if the 502 is a gen 5 or gen 6 and buy the right head gasket.the head gasket's are different around the water passages.
contagious is offline
