400 sbc 2 bolt main suggestions?
Old 11-21-2010, 04:44 PM
Drtmod5
Default 400 sbc 2 bolt main suggestions?
I recently picked up this standard bore block for next to nothing. I have heard the horror stories about these 400's, but am curious as to what others think before I possibly waste my money. This motor will be a circle track motor so filling the block won't be an option. Is it worth the time or should I stay with another 383-388 combo like I have now? Any help is appreciated.
Thanks, Dave
Drtmod5 is offline
Old 11-21-2010, 06:00 PM
mytmouz
mytmouz's Avatar
Are the aftermarket blocks available now better? Yes. Did the stock stuff work for years when the aftermarket stuff wasn't available? Yes. Personally, if I had the stock block, I would install the splayed caps and run it. I have a production block in mine now, and just got a heck of a deal on a little m crate motor that didn't live. I ain't pulling the motor out just to change the block...
mytmouz is offline
Old 11-21-2010, 09:36 PM
hink
Default Re: 400 sbc 2 bolt main suggestions?
Thanks, Dave
Before you spend any money on that block have it sonic tested first!!
hink is offline
Old 11-22-2010, 05:46 AM
DirkaDirka
DirkaDirka's Avatar
I got one in my 84 Chevy 4x4 and right now I am having a hard time keeping it cool. I dont know if that is a problem with the 400s or not. I know that the one in my 4x4 has a mild cam and around 10:1 compression. I didnt build the motor or have it built so I cant tell you everything that has been done to it. I do have a set of Hooker Headers with 2 1/2" exhaust into dual flowmasters. It sounds good and runs good jsut need to figure out my overheating problem.
DirkaDirka is offline
Old 11-22-2010, 06:03 AM
The 509 casting blocks are suppose to be the best of the bunch. If its not I wouldnt use it
Old 11-22-2010, 01:23 PM
I never had one iota of trouble keeping an 11 to 1 compression 406 cool on the street. Ran 180 in traffic. I've had 3 different 406's in street cars none of them ran hot. I think that is just a myth.
x2 on the 509 being the best one. That's what they say.
Old 11-22-2010, 02:13 PM
kwkracing
If your runing a imca class that is using a stock block, you will have no troubles, the engine will tear up of other reasons, before you should worry about the block or mains. Put a some arp studs and go racing!
kwkracing is offline
Old 11-22-2010, 02:25 PM
jasonwfo1
i ran a 434 in a 511 block for a few years, the 400 blocks like to crack from the upper head bolt holes to the larger 1/2 inch circle water passages, i seen this in bone stock 400's,check yours, would almost bet you will find a crack.
jasonwfo1 is offline
Old 11-22-2010, 02:26 PM
Drtmod5
It's a 511 block #, and we run under UMP rules. Thanks for the replies.
Drtmod5 is offline
Old 11-22-2010, 03:52 PM
I thought the 511 was the 3 freeze plug 4 bolt main casting? they are the ones with the worst reputation. all mine were 4 bolt main 3 freeze plug blocks. only street motors though.
