chevette help
i`m thinking more room for headers if i relocate the master cylinder to the inside of the car on the left and a small starter on the right and a narrowing and reboxing of the front subframe. on the right....i need some input here. i`m gona contact some header manufactuers direct. theres nil for room in there.
well... i want to run the stock inner fenders, its also the upper shock mount and its structural to the front subframe assembly. if it was a full cage as opposed to my bar set up i could do the shock mounts to the front engine compartment bars... but thats not what i have. idealy i like to have a bigger tube street rod "hugger" header that was actually made for my applcation. anyways thnx for the input.
don't know about running stock fender wells....but here is my Friends 1977 Honda Civic 555ci alcohol blown injected BBC.....The Vid you are seeing is a 4.69et pass 150mph +.....you should see it when he runs 40%-50% nitro.. :roll:
the civic might even have a little shorter wheel base then your chevette..
Danny has real Big balls driving this car....see the other Vids attached and watch the man drive this car....
http://www.youtube.com/watch?v=mYzKN...eature=related
